hi,
I am using the N1911A power meter and the N1921A power sensor for measurement of peak power. I would like to know the procedure for calculating the pulse droop.
Rgds
Rgds
Then place Market 2 just before the falling edge of the pulse. Typically this would be about 10% of the time before the falling edge of the pulse. Note this marker's time and magnitude.
The difference in time between the two markers is the droop time. The difference between the two marker magnitudes is the actual droop value.
