Hello currently the Agilent GUI Data Logger Basic Edition, exports only at *.CSV format.
And this limited option by it self, it cause stress to any one who uses the Microsoft office Excel 2003,
simply because its and every time, he must import the CSV in to Excel , by using the special import function.
And this is a bit hard to do, and almost an waste of time.
I have two suggestions for the Agilent team who does the software work,
1) add as additional option, output to *.xls format.
2) the software must have the ability to load exported files as *.CSV or *.xls ,
and to operate as viewer of older saved logs.
Those corrections - additions will help lots of people out there.
As soon you inform your software team, please let me know about their plans.
Thanks.
Thanks.
Regards.
The data logger monitors the range switch position, and auto adjusts accordingly.
unfortunately at the U1272A the software does not understand the change in the selection between the capacitor range,
that becomes also as temperature range with the key pad !!
And so even if you log temperature the data logger indicates that it is in the capacitor range and adds on the log the word CAP.
Even if correctly records temperature.
Its a small annoyance and should be fixed, logically it should write TEMP instead of CAP.
Thanks.
