In newer versions of VEE (8.x that I know of) you can. In a formula box, write userFunction.PopupPanelTitle="Your Title Here";, where userFunction is the name of your user function.
L
Sent: Thursday, September 25, 2008 11:08 AM
To: VRF
Subject: [vrf] User Function properties...
Greetings all,
Does anyone know if it is possible to set the properties of a user function programmatically? I’d especially like to be able to change the pop up title based on which test is running. I suppose I could have 2 versions of the function with the pop up titles hard coded and just call the one I want, but I was hoping for something a little more elegant that wouldn’t require maintaining both functions.
Thanks in advance,
Doug
Douglas B. Rudrow
Systems Development Lab Technologist
Aurora Networks
2803 Mission College Blvd.
Santa Clara, California, 95054
U.S.A.
(408) 235-7000 Main
(408) 235 7084 Direct
HYPERLINK "mailto:drudrow@aurora.com"drudrow@aurora.com
You are currently subscribed to vrf as: lorne.roy@philips.com
_____
The information contained in this message may be confidential and legally protected under applicable law. The message is intended solely for the addressee(s). If you are not the intended recipient, you are hereby notified that any use, forwarding, dissemination, or reproduction of this message is strictly prohibited and may be unlawful. If you are not the intended recipient, please contact the sender by return e-mail and destroy all copies of the original message.
You are currently subscribed to vrf as: hua_jing@agilent.com
L
To: VRF
Greetings all,
Thanks in advance,
Doug
Douglas B. Rudrow
Aurora Networks
U.S.A.
(408) 235-7000 Main
_____
--- You are currently subscribed to vrf as: hua_jing@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
