vrf Run Time Error writing to Excel
Question asked by VRFuser on Sep 18, 2007
I also had several problems with that option. Found out there were several errors on programming manual. Download latest version from Agilent site and check if commands differ. I remember some quite basic commands like Calibrate had an error.
Regards
Seppo Forssell
ATE Engineer
Lainaus "Doe, Munehiro" <Munehiro.Doe@Herley.Com>:
> I do not know where to do a search on previously posted inquiries on
> this forum so I am sending this.
> I am having a programming problem with four of the Noise Figure module
> programming commands.
> My configuration is:
> Agilent E4440A firmware:  A.09.19
> Option 219 Noise Figure firmware:  A.01.09
> All commands were sent while the E4440A was in Noise Figure Mode.
> The corresponding commands for Setting of values worked fine.
> SCPI command strings cut/pasted from code are:
> ":DISPLAY:NFIGURE:TRACE:Y:SCALE:PDIVISION?"                page 279
> "DISPLAY:NFIGURE:TRACE:Y:SCALE:RLEVEL:VALUE?"         page 280
> "DISPLAY:NFIGURE:TRACE:Y:SCALE:RPOSITION?"                page 281
>         These all gave an error on the E4440A of:  -420 query
> UNTERMINATED and -109 Missing Parameter
> Reference pages are from "Agilent ESA-E Series and PSA Series Spectrum
> Analyzers Noise Figure Measurement Personality Guide Option 219"
> ":SENS:NFIG:CORR:COLL:ACQ"              page 342
>         This did not initiate a calibration sequence.
>         Note:  noise source was not hooked up.  Calibration sequence can
> be initiated by the front buttons.
> Thanks in advance for check on your equipment.
> M. Doe
> You are currently subscribed to vrf as: seppo.forssell@mil.fi
> To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with
> the word subscribe in the message body.
> To send messages to this mailing list,  email "vrf@agilent.com".
> Search the "unofficial vrf archive" at
> "http://www.vrfarchive.com/vrf_archive".
> Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
Tämä sähköpostiviesti on tarkoitettu vain vastaanottajalle. Viesti voi
sisältää luottamuksellista tietoa. Jos olet vastaanottanut tämän
sähköpostiviestin vahingossa, palauta se lähettäjälle. Älä muuta
sähköpostiviestin sisältöä tai levitä sitä eteenpäin.
Kiitos.
This e-mail is intended only for the addressee. This e-mail may contain
privileged and confidential information. If you receive this e-mail by
mistake, please return it to the sender without producing, distributing or
retaining copies thereof.
Thank you.
