I set up the sweep signal on N5182A and set the "trigger out" as "sweep trigger". The trigger signal I measured from trigger out repeat every 5 ms. Other then most frequently appeared 50 us pulse width, there is a type of pulse width about 1.3 ms. Does anyone know what's that? or is there a document talking about it? Thanks.
wei
wei
