I working on integration of VEE user function into Visual Basic taking reference of Callable AciveX Automation Server in Microsoft Visual Studio 2008. I first tried with very simple example and i called it from Visual basic code and it worked fine. But when i introduced some .NET code into that example. It works fine in VEE Pro. But when i called it from visual basic it failed.
It gives me error saying "ComException was unhandled", cannot access .NET object to perform operations. VEE Error No: 754 at line where i am calling that function. One more error saying "Could not resolve COM reference "36f6e2f6-a9ce-11d4-98e5-00108301cb39" version 1.0. The type library importer encountered an error during type verification. Try importing without class members." VB code is as follow:
I have attached snap shot of error message, which i got in MS visual studio 2008.
Public Class Form1
Dim server As New CallableVEE.CallServer
Dim library As CallableVEE.Library
Dim calcUF As CallableVEE.UserFunction
Dim libfile As String
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
libfile = "C:\SDA_VEE_Control\Var_Calc.vee"
server = CreateObject("CallableVEE.CallServer")
library = server.Libraries.Load(libfile)
calcUF = library.UserFunctions("Calc")
calcUF.Call() '----------------------------- Errored Line
End Sub
End Class
I suspect it has to do with COM and .Net interoperability. Can anyone tell me how to resolve this problem or require more infomation on it. Thanks in advance.
Public Class Form1
End Sub
End Class
Sounds like VEE is trying to call a variable that hasn't been initialized, or is otherwise used improperly.
