That depends on what you're machining. I wrote software in VEE that controls a 3-axis welder (bit-banged the steps to each motor via Measurement Computing DIO card). Since all we welded were squares and rectangles synchrony was not an issue.
Ashley?
Bill
From: HOUSTON,TOM [mailto:tom.houston@avagotech.com]
Sent: Thursday, October 25, 2007 9:17 AM
To: VRF
Cc: vrf@agilent.com
Subject: RE: [vrf] CNC Mill control
The problem with controlling a mill is that both motors have to be stepped synchronously. This is very hard to do in a Windows app. The only way to get good smooth control is to write a kernel level app that sits under windows to do the actual stepping.
_____
From: Ashley Derrick [mailto:ashley@smartsolutions.karoo.co.uk]
Sent: Thursday, October 25, 2007 1:16 AM
To: VRF
Subject: [vrf] CNC Mill control
Hi I have a small copmbined lathe / Milling machine (EMCO Emcomat 7)
Has any one done two axis (XY) control of Mill using VEE. I have my own cards which control stepper motors via RS232 using a PC micro. If so any examples please?
rgs Ashley
You are currently subscribed to vrf as: tom.houston@avagotech.com
You are currently subscribed to vrf as: William.Drago@l-3com.com
Ashley?
Bill
To: VRF
Cc: vrf@agilent.com
_____
To: VRF
rgs Ashley
rgs Ashley
