Skip navigation
Register
Home
Forums
Blogs
Help
My Links
My Bookmarks
My Questions
My Places
Log in
0
Search
Search
Search
Cancel
Error: You don't have JavaScript enabled. This tool uses JavaScript and much of it will not work correctly without it enabled. Please turn JavaScript back on and reload this page.
All Places
Discussion Forums
Waveform Generators
Questions
Log in
to create and rate content, and to follow, bookmark, and share content with other members.
Answered
Assumed Answered
81110A Manual trigger
Question asked by
sking
on Jun 13, 2011
Latest reply
on Jun 14, 2011 by sking
Like
Show 0 Likes
0
Comment
2
Is there a way of simulating the manual trigger key on the front panel of the 81110A through remote control (LAbview)?
cheers,
This content has been marked as final.
Show 2 comments
Name
Email Address
Website Address
Name
(Required)
Email Address
(Required, will not be published)
Website Address
lhornburg
Jun 13, 2011 10:35 AM
Mark Correct
Correct Answer
I haven't used this particular instrument, but in general you should be able to use the "*TRG" command to send a trigger to SCPI instruments.
sking
Jun 14, 2011 3:24 AM
Mark Correct
Correct Answer
thanks, I amanged to do it with the SYST:KEY: command to simulate the actual key press. I guess the TRG would be better. I am also having problems with intermittant communication timeouts when I try to send a command via GPIB. Any ideas?
cheers,
cheers,
