Doug,
What I do in 7.52, is to have a label at the top of the panel with an data input pin on it, and in the properties of the Function I turn OFF the Title Display on the panel. Then I can either send a variable to the Label, or hard wire it. the beauty of using the variable is of course, you can use an On Cycle object to get the variable, and resend it to the label, or only send it to the label if it is not the same as the previous using a shift register.
It also gives you a few more formatting options, like centreing the text, 3D Label etc.
That way the one function can be use for numerous uses.
Cheers,
Gary
Gary Voltz
SASTO4
Test Equipment and Maintenance and Calibration Centre
Facilities Management Services
Technology and Asset Services
Airservices Australia
E-mail: gary.voltz@airservicesaustralia.com
_____
Ph 1300 301 120 (within Australia)
Ph +61 7 3866 3382 (outside Australia)
Fax +61 7 3866 3531
HYPERLINK "http://www.airservicesaustralia.com/"www.airservicesaustralia.com
CAUTION: This e-mail is confidential. If you are not the intended
recipient, you must not disclose or use the information contained
in it. If you have received this e-mail in error, please tell us
immediately by return e-mail and delete the document.
Airservices Australia does not represent, warrant or guarantee
that the integrity of this communication is free of errors, virus
or interference.
_____
Sent: Friday, 26 September 2008 4:08 AM
To: VRF
Subject: [vrf] User Function properties...
Greetings all,
Does anyone know if it is possible to set the properties of a user function programmatically? I’d especially like to be able to change the pop up title based on which test is running. I suppose I could have 2 versions of the function with the pop up titles hard coded and just call the one I want, but I was hoping for something a little more elegant that wouldn’t require maintaining both functions.
Thanks in advance,
Doug
Douglas B. Rudrow
Systems Development Lab Technologist
Aurora Networks
2803 Mission College Blvd.
Santa Clara, California, 95054
U.S.A.
(408) 235-7000 Main
(408) 235 7084 Direct
HYPERLINK "mailto:drudrow@aurora.com"drudrow@aurora.com
You are currently subscribed to vrf as: gary.voltz@airservicesaustralia.com
You are currently subscribed to vrf as: hua_jing@agilent.com
Cheers,
Gary
Gary Voltz
SASTO4
_____
Fax +61 7 3866 3531
or interference.
_____
To: VRF
Greetings all,
Thanks in advance,
Doug
Douglas B. Rudrow
Aurora Networks
U.S.A.
(408) 235-7000 Main
Thanks in advance,
Doug
Douglas B. Rudrow
Aurora Networks
U.S.A.
(408) 235-7000 Main
