The ID compiler is still stay in VEE directory. You may see the idc.exe which is a DOS utility. You may execute it in DOS shell. Once you get id file, you can use it to convert to cid file.
Best regards,
Jiann-Der Shaw
Measurement Systems Operation
Agilent Technologies
IDD: 886-3-4959344
Telnet: 846-3344
Mobile: 886-917672043 (0917672043 in Taiwan)
_____
From: William.Drago@L-3com.com [mailto:William.Drago@L-3com.com]
Sent: Thursday, October 18, 2007 6:57 AM
Subject: RE: [vrf] Where can I get Compiled instrument drivers?
Well, if your trying to run a .vxe that is of little help. But, I wrote a dummy program to use the .id driver and VEE did make the.cid for me.
Thanks, problem solved.
Bill
Sent: Wednesday, October 17, 2007 6:40 PM
To: VRF
> Yes, there's a utility--don't know where to find it. The kicker is, a colleague downloaded the 436.cid from
> Agilent's site a few weeks ago, so there must be a collection of them somewhere.
Did something change in VEE? Previously it automatically did the conversion from .id to .cid and left the .cid on your hard drive. Try the .id and see what happens.
~~Les Hammer
You are currently subscribed to vrf as: William.Drago@l-3com.com
You are currently subscribed to vrf as: jiann-der_shaw@agilent.com
Best regards,
Jiann-Der Shaw
IDD: 886-3-4959344
Telnet: 846-3344
_____
Bill
To: VRF
~~Les Hammer
We have Vee Pro 8.0 and we are trying to learn how to get data from an A/D converter made by NI. It is a USB 6211.
We can pull down Instrument Manager from I/O. Undef NIDAQ Devices we find
USB6211(@17->NI-DAQMX) When we click on NI-DAQMX Driver on the right hand side of the screen we are provided with a to/from USB6211 module. When we double click to add function we are presented with a great variety of choices and have no idea what to do. Any suggestions? An example using an NI-DAQ MX device would be great, we have not been able to find one.
Thank you
Bob and Mike
