I run in agilent vee 7.5 an example called "MATLAB_Digital_Processing.vee". Before i install the new Agilent Libraries IO 15.5 the example was running excellent. But now an error occured about GPIB number.
The gpib number in scope.exe from utilities menu is 7. But the error is "GPIB Interface at 7 is not configured for this system"
If i look to Agilent Connection Expert i have GPIB0 with address 21, SICL interface ID gpib1 , Logical Unit 9 , Board Number 0 .
Which parameter i must change in order to fix this problem?
Can anyone help me?
Can anyone help me?
From the description, I think you should change Logical Unit (aka select code) to 7 in ACE. Normally the first GPIB card will be assigned logical unit 7 but in thie case it seems to be 9.
Dont mix up the interface select code (logical unit) and instrument address, both are 7 in this case. The complete address for the scope (at address 7) will then be 707.
