I have a Agilent 2000 oscilloscope with WaveGen option installed. I am using to test an ADC Module from TI, specifically it is ADS1278EVM module.
I have the WaveGen generating a 5VPP sine wave with no offset voltage. When I connect my oscilloscope input to the wavegen output I see the sine wave but the voltage is showing 0.3VPP (about 0.3V~, rms, I also have the DVM Option installed). I see this both with high-z setting and 50ohm. I have the WaveGen ground connected with the oscilloscope ground.
This is exactly what I observe through my ADC module as well (I have an fpga as my dsp connected to my computer).
Can you please advice why am i not seeing the full 5VPP?
I don't know what the input impedance of your device is, but unless it's High-Z, you won't ever see 5V pk-pk.
Al
