pls anyone has an idea on how to convert a file in excel format to a format that can be viewed with the agilent intuilink waveform editor?? i have attached the file im trying to upload...
The easiest method is to save the excel data as a CSV format. Place all the values in Column A, and select File -> Save As... and save as type CSV. You can also use tab separated TXT.
I hope that helps!
-- Cheryl
