Scott,
Thanks I’ll give it a try……..
Scott Grose
Sr. Systems Engineer
General Dynamics SATCOM Technologies
4825 River Green Parkway
Duluth, Georgia 30096
Office: 770-689-2054
Cell: 404-276-8596
Fax: 770-476-7092
HYPERLINK "http://www.gdsatcom.com/"www.gdsatcom.com
_____
From: MORRISON,SCOTT (A-Sonoma,ex1) [mailto:scott_morrison@agilent.com]
Sent: Monday, September 22, 2008 12:30 PM
To: VRF
Subject: RE: [vrf] FW: E8257D PSG Analog Signal Generator
Hi Scott,
I think you’ll find that panel drivers are a thing of the past. You may have some luck loading up the panel drivers for the hp83620a or hp83640a (both .cid files available with vee install), however they certainly won’t help with regard to some of the more modern features of your E8257. I believe the E8257 is backwards compatible with the 836XX family of sources.
I note that there is a tab for “programming examples” listed under E8257 on Agilent’s main web page. I also found this SCPI programming summary:
http://cp.literature.agilent.com/litweb/pdf/E8251-90356.pdf
Hope it helps,
Scott
_____
From: Grose, Scott [mailto:Scott.Grose@GDSATCOM.com]
Sent: Friday, September 19, 2008 6:13 AM
Subject: [vrf] FW: E8257D PSG Analog Signal Generator
All,
Does anyone know where I can find a panel driver Or and example for an E8257??
Scott Grose
This email message is for the sole use of the intended recipient(s) and may contain General Dynamics SATCOM Technologies confidential or privileged information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not an intended recipient, please contact the sender by reply email and destroy all copies of the original message.
You are currently subscribed to vrf as: scott_morrison@agilent.com
You are currently subscribed to vrf as: Scott.Grose@gdsatcom.com
You are currently subscribed to vrf as: hua_jing@agilent.com
Scott Grose
Cell: 404-276-8596
Fax: 770-476-7092
_____
To: VRF
Hi Scott,
Hope it helps,
Scott
_____
All,
Scott Grose
All,
Scott Grose
