History:
During working with VEE Pro 8.51 I’ve got a blue screen by windows XP (SP 3) telling me, that there might be a problem with some new hardware. And indeed I was just working with a very new USB scope (PicoScope).
Symptoms:
Since this system crash VEE 8.51 doesn’t start anymore. I always get the error message below:
![Image]()
But VEE RunTime (8.51) still runs and VEE Pro 7.03 also. Nothing else on my computer seems to be affected beside VEE Pro 8.51. I reinstalled VEE Pro 8.51 without success. I still get the same error massage every time I try to start VEE Pro 8.51.
So my question: What can I do to make VEE Pro 8.51 running again?
Symptoms:
I faced similar problem before which is unable to start VEE. I had performed following steps and the problem gone:
1. Delete all files in temp folder (goto run and type %Temp% )
2. Delete all files in C:\Documents and Settings\<Username>\Application Data\Agilent\VEE Pro\8.5 (or 8.51)
Hope this helps.
