vrf RS-232 interface Modbus RTU protocal over ADAM 6017
Question asked by VRFuser on Oct 23, 2007
Hello Sebastian and the VRF,
I already tried that and it doesn't work. However, if I restore and then minimize the Word window it runs very fast. No matter what I do within the program (visible, not visible, minimize, maximize then minimize) it runs slow. The only way I can get it to run fast is with some kind of manual interaction with the Word window.
This is very strange... And I really need a solution.
Is anyone using ActiveX with Word successfully/reliably?
Bill
From: Donner, Sebastian [mailto:sebastian.donner@kriwan-testzentrum.de]
Sent: Tuesday, October 23, 2007 3:01 AM
To: VRF
Subject: AW: [vrf] Word slow via ActiveX
Hi William,
if you hide Word. It think it runs with the same speed every time.
wordApp.Visible = false;
(An interessting thing is, if you run the example and click on the Scrollbar, Word runs very fast! But why, i dont know?)
Best regards Seabstian
Mit freundlichen Grüßen
i. A. Sebastian Donner
Sebastian Donner
KRIWAN Testzentrum GmbH & Co. KG
Teslastr.2, D-74670 Forchtenberg
Tel: 07947/9150-0  Fax: 07947/9150-50
Sebastian.Donner@KRIWAN-Testzentrum.de
www.KRIWAN-Testzentrum.de
Von: William.Drago@L-3com.com [mailto:William.Drago@L-3com.com]
Gesendet: Montag, 22. Oktober 2007 20:25
An: VRF
Betreff: [vrf] Word slow via ActiveX
All,
I'm currently writing code to transfer a LOT of data to Microsoft Word and the transfers sometimes take a very long time. And other times, they're lightning fast.
Even when I run the example WordDataSheet.vee found here:
C:Program FilesAgilentVEE Pro 8.0examplesActiveXAutomation
Sometimes it runs very fast, other times very slow. I haven't found a way to get it to run fast all the time.
Anyone have any experience with this sort of thing?
Bill
You are currently subscribed to vrf as: sebastian.donner@kriwan-testzentrum.de
You are currently subscribed to vrf as: William.Drago@l-3com.com
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender und loeschen Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
Eingehende E-Mails mit folgenden Anhangs-Endungen werden aus sicherheitsgründen automatisch abgewiesen:
PIF, SCR, BAT, URL, EXE, COM, DLL, HTA, VBS
This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and delete this e-mail. Any unauthorized copying, disclosure or distribution of the contents in this e-mail is strictly forbidden.
Incoming E-Mails with the following attachement-extensions are automatically rejected for security reasons:
KRIWAN Testzentrum GmbH & Co. KG  -  AG Stuttgart: HRA 590480
Komplementär:
KRIWAN Verwaltungs-GmbH  -  AG Stuttgart: HRA 590645
Geschäftsführer: Dr. Ing. Elmar Zeitler, Dipl.-Ing. Jens-Peter Huischen
