Anyone know how to allow editing of a formula box while running the program?
I want the user to be allowed to modify the formula (numbers & operators) while the program is running. Thanks.
Matthew Boespflug
GE Global Research
1 Research Circle
ES - 508c
Niskayuna, NY 12309
Phone: 518-387-5017
Fax: 518-387-7989
boespflu@research.ge.com
GE Company Proprietary Information
HYPERLINK "file://www.geglobalresearch.com"www.geglobalresearch.com
Matthew Boespflug
GE Global Research
1 Research Circle
ES - 508c
Niskayuna, NY 12309
Phone: 518-387-5017
Fax: 518-387-7989
Paul.
Sent: 30 October 2007 11:10
To: VRF
Subject: [vrf] DISPLAY question
To All,
I am trying to display the contents of a variable via the formula in My example. I expect to see 5 X, instead I see [DN0]. What step am I leaving out?
Dave
You are currently subscribed to vrf as: Paul.Carnell@icstriplex.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com"
Information Contained in this Email plus any attachments is for the use of the intended recipient only and is confidential, proprietary and may be privileged. Any dissemination, distribution, copying or use of this communication without prior permission of the sender is prohibited. If you are not the intended recipient you must not copy this message or any attachments or disclose the contents to any other person and you are requested to Email the sender, or telephone ICS Triplex on +44 1621 854444 and delete the message and any attachment from your system. Opinions, conclusions and other information in this message that do not relate to the official business of ICS Triplex shall be understood as neither given nor endorsed by it. ICS Triplex accept no responsibility for any virus or defect that might arise from opening this Email or attachments.
