"Boespflug, Matthew (GE, Research)" <boespflu@research.ge.com> wrote:
> Anyone know how to allow editing of a formula box while running the
> program?
> I want the user to be allowed to modify the formula (numbers &
> operators) while the program is running. Thanks.
Sure. Have the user input the formula in any text input object and then pipe the formula into the "formula" control input of your Formula object. A text constant works fine. Would suggest inputting the existing value of the formula into the text constant before allowing user to edit.
You'll of course get no active debugging-- so if user creates syntax error, such is life.
Stan
> program?
Stan
I want the user to be allowed to modify the formula (numbers & operators) while the program is running. Thanks.
Matthew Boespflug
GE Global Research
1 Research Circle
ES - 508c
Niskayuna, NY 12309
Phone: 518-387-5017
Fax: 518-387-7989
GE Company Proprietary Information
HYPERLINK "file://www.geglobalresearch.com"www.geglobalresearch.com
