When using my 33220A in Burst Mode on external trigger, I notice a delay of about 375ns between the trigger input and the signal output. Any ideas why this delay is here or how I can eliminate it?
If you look at the specs under trigger characteristics the input trigger latency is spec'd as less than 500ns, so 375ns is well within specs. I don't think there is anything wrong.
