vrf Bulky Data Set
Question asked by VRFuser on Feb 13, 2003
Can you delete records from a dataset?  Not as such.  Read all of the
records which will give you an array of records.  Delete the required
records and resave.
There are several ways to remove a record but here is one way; if the input
pin is called RecAry:
concat(RecAry[0:3],RecAry[5:*])
returns RecAry with record index 4 removed.
If you would like an example please let me know.
Hope that helps,
Mike Watts
