Hello All,
I'm trying to get set up with Agilent VEE and I'm encountering some issues. When I open Agilent Connection Expert my two devices are found (with green check marks) but when I use the Instrument Manager and "Find" I get a "No interface detected" message at the bottom of the screen. Seems like this should be a very basic issue but I'm really struggling with it. Here are the system details:
82357B USB to GPIB adapter
Agilent VEE express version 9.2
Agilent Connection Expert version 15.5
WinXP PC
I appreciate any help!
Tom
WinXP PC
Tom
Not sure if you are aware that VEE Express support only Agilent USB interface http://www.home.agilent.com/agilent/editorial.jspx?cc=US&lc=eng&ckey=1197720&nid=-34095.806312.00&id=1197720.
If you are using 82357B USB to GPIB adapter, I guess your instrument is not USB interface and VEE Express won't be able to detect it. If your instrument has USB interface, use it instead of 82357B USB to GPIB adapter.
Hope this helps.
-mk
