I'm trying to dump data from VEE to an embedded graph object in microsoft word. I have tried recording a macro to see the visual basic code generated, but the macro recorder does not record any actions performed inside the embedded object.
I have tried as both a "Microsoft Excel Chart" and a "Microsoft Graph Chart" (I have no preference over which one to use, both would do the job), but had no luck with either. All I need to do is dump results into the graph, I don't need to create a new object as I will be dumping data into an existing chart object.
Does anyone know how I might be able to do this using active x?
Steve
--- You are currently subscribed to vrf as: ming_meng@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
Steve
