Or just have a look in examples/ActiveXAutomation/word.vee
Von: Baranski, Detlef [mailto:Detlef.Baranski@pilkington.de]
Gesendet: Mittwoch, 24. Oktober 2007 11:56
An: VRF
Betreff: AW: [vrf] Dumping data to an embedded graph in MS word
One other way is using the ctrl-C and Crtl-V window functionality. You may use the "keyboard-simulator" sendkeys.
But there should be also some .net functions for this, so this solutions seems not to be the most elegant- but it works
detlef
________________________________
Von: Willging, Claudia [mailto:claudia.willging@kriwan-testzentrum.de]
Gesendet: Mittwoch, 24. Oktober 2007 11:24
An: VRF
Hi Steve,
one way to do it is to create a graph in Vee, save it as *.jpg and after that insert your *.jpg into a Word document. Would that be an opportunity for you?
Mit freundlichen Grüßen
i. A. Claudia Willging
Dr. Claudia Willging
KRIWAN Testzentrum GmbH & Co. KG
Testlastr. 2, D-74670 Forchtenberg
Tel.: (07947) 9150-0 (Durchwahl 9365) Fax: (07947) 9150-50 claudia.willging@KRIWAN-Testzentrum.de
www.KRIWAN-Testzentrum.de
Von: Stephen Hobson [mailto:shobson85@googlemail.com]
Gesendet: Mittwoch, 24. Oktober 2007 11:11
An: VRF
Betreff: [vrf] Dumping data to an embedded graph in MS word
I'm trying to dump data from VEE to an embedded graph object in microsoft word. I have tried recording a macro to see the visual basic code generated, but the macro recorder does not record any actions performed inside the embedded object.
I have tried as both a "Microsoft Excel Chart" and a "Microsoft Graph Chart" (I have no preference over which one to use, both would do the job), but had no luck with either. All I need to do is dump results into the graph, I don't need to create a new object as I will be dumping data into an existing chart object.
Does anyone know how I might be able to do this using active x?
Der Inhalt dieser E-Mail (inkl. aller Anlagen) ist vertraulich und ausschließlich für den Adressaten bestimmt. Jede Art der Verbreitung, Nutzung oder Vervielfältigung ist untersagt. Sollten Sie diese E-Mail irrtümlich erhalten haben, informieren Sie bitte sofort den Absender und löschen die E-Mail.
Unternehmensangaben der Gesellschaften mit Sitz in Deutschland:
Pilkington Holding GmbH, Haydnstraße 19, 45884 Gelsenkirchen
Sitz: Gelsenkirchen, Amtsgericht Gelsenkirchen HRB 8997
Geschäftsführung: Jochen Settelmayer (Vorsitz), Dr. Clemens Miller, Thomas Kretschmann, Robert Hales Vorsitzender des Aufsichtsrates: Dr. Axel Wiesener
Pilkington Deutschland AG, Haydnstraße 19, 45884 Gelsenkirchen
Sitz: Gelsenkirchen, Amtsgericht Gelsenkirchen HRB 2707
Vorstand: Dr. Clemens Miller, Jochen Settelmayer Vorsitzender des Aufsichtsrates: Dr. Axel Wiesener
Pilkington Automotive Deutschland GmbH, Otto-Seeling-Straße 7, 58455 Witten
Sitz: Witten, Amtsgericht Bochum HRB 8443
Geschäftsführung: Thomas Kretschmann
Vorsitzender des Aufsichtsrates: Jochen Settelmayer
Bauglasindustrie GmbH, Hüttenstraße 33, 66839 Schmelz / Saar
Sitz: Schmelz / Saar, Amtsgericht Saarbrücken HRB 52020
Geschäftsführung: Manfred Ebbers
An: VRF
detlef
An: VRF
Hi Steve,
An: VRF
An: VRF
Steve
--- You are currently subscribed to vrf as: claudia.willging@kriwan-testzentrum.de To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender und loeschen Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
Eingehende E-Mails mit folgenden Anhangs-Endungen werden aus sicherheitsgründen automatisch abgewiesen:
PIF, SCR, BAT, URL, EXE, COM, DLL, HTA, VBS
This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and delete this e-mail. Any unauthorized copying, disclosure or distribution of the contents in this e-mail is strictly forbidden.
Incoming E-Mails with the following attachement-extensions are automatically rejected for security reasons:
KRIWAN Testzentrum GmbH & Co. KG - AG Stuttgart: HRA 590480
Komplementär:
KRIWAN Verwaltungs-GmbH - AG Stuttgart: HRA 590645
Geschäftsführer: Dr. Ing. Elmar Zeitler, Dipl.-Ing. Jens-Peter Huischen
