Hi VRF
Concerning the delete library object
I have a program which was designed to be as flexible as possible. Thus when a measurement is made, the data get passed through a "post processor". The processor loads in function libraries, processes the data and outputs an answer. So far this method has worked very well. But I get the feeling that the delete library function does not free up used memory.
Last time I checked the page file usage goes up beyond 1GB when the veerun.exe is reporting much less. When the program closes the page file usage goes down to around 400mb.
Is there a way to make sure that the program frees up used memory when the imported user functions are deleted.
Thanks
Jacob Meachen
Thanks
Jacob Meachen
