Hi Vrf
I have been sent a Vee program written in our Japan office using version
6.2. However when I try to open it, I get the following message at several
different lines.
Does anybody know how I can Fix this?
<<...OLE_Obj...>>
Regards
Paul Johns
different lines.
<<...OLE_Obj...>>
Regards
Paul Johns
settings for Japan. The most probable cause is that there are
characters that are valid in Japanese but not in English. This will be
difficult to fix because you need to find the offending ones first. My
suggestion is that you change your pc settings to those used in Japan.
You will probably need to install east Asian language fonts as well.
Then you might be able to open the VEE program.
Can't be more help as the picture of the message didn't come through.
Adam Kohler
Software Test
EPSG
Agilent Technologies
Scotland
tel net 313 5327
t +44 131 335 7327
e adam_kohler@agilent.com
From: Johns, Paul (EU-SES) [mailto:Paul.Johns@eu.sony.com]
Sent: 06 April 2005 09:45
To: VRF
Subject: [vrf] ILLEGAL ESCAPE SEQUENCE
Hi Vrf
several
different lines.
<<...OLE_Obj...>>
Regards
Paul Johns
You are currently subscribed to vrf as: adam_kohler@agilent.com
