Sadly, I think the easiest way is to use error pins & learn about their
odd behaviour! The unexpected will then become the expected. To be
honest, I find they behave mostly ok, as long as they are connected to
something.
Dave
[mailto:alexander.poulikakos@ericsson.com]
Sent: 06 September 2005 14:47
To: VRF
Subject: [vrf] Check if a variable has been initiated or not
Hi VRF
Is there a way to check if a variable has been initiated (set), without
using
an error pin? I'd like to avoid error pins as the tend to cause
unexpected behaviors.
/Alex
You are currently subscribed to vrf as: watling@icerasemi.com
something.
Dave
To: VRF
Hi VRF
using
/Alex
Is there a way to check if a variable has been initiated (set), without using
an error pin? I'd like to avoid error pins as the tend to cause unexpected behaviors.
/Alex
