If you do not have any VXI cages or any other VXI, use the agilent, only.
If you are using both VXI and GPIB you'll need the VISA, pick which one you
will use, but not both.
So first determine what you really need.
rufus
From: Thomas.Mitchell@Autoliv.com [mailto:Thomas.Mitchell@Autoliv.com]
Sent: Friday, January 14, 2005 3:39 PM
To: VRF
Subject: [vrf] VISA Question
I'm in the middle of my test program and I ran into an issue that I can't
figure out. I'm using a National GPIB card in my PC, and I was using the
Agilent VISA drivers. My PC has stopped communicating with my test
equipment. I started the NI program MAX, and I cannot scan for instruments.
When I click on interfaces, I see a notification for a VISA error. I called
NI, and they tell me to re-load the NI VISA drivers over the Agilent VISA
drivers.
>From what I remember from a few years ago, there was some kind of an issue
when using both VISA drivers. The NI software will copy the Agilent VISA as
another name. I guess my question is, should I use the NI VISA or Agilent
VISA with VEE?
I uninstalled all of the NI software and hardware, the Agilent IO libraries,
and reinstalled everything, and I still have the same problem.
On Monday, I'll see if I can find another PC to check my card in, or try to
find another card for my PC. Any ideas?
Thanks
Tom Mitchell
Autoliv AEA
You are currently subscribed to vrf as: rwarren@amti.net To subscribe send a
blank email to "join-vrf@it.lists.it.agilent.com".
rufus
To: VRF
drivers.
VISA with VEE?
Thanks
Tom Mitchell
Autoliv AEA
called NI, and they tell me to re-load the NI VISA drivers over the Agilent
VISA drivers.
VISA with VEE?
libraries, and reinstalled everything, and I still have the same problem.
to find another card for my PC. Any ideas?
Thanks
Tom Mitchell
Autoliv AEA
