Griggs, Jon wrote the following:
> Please take the following with a tablespoon of salt... I can't find the reference I was looking for and produced the following from memory.
> Correction would be appreciated...
> While very hazy, I do remember that two things affect communication.
> The first is total cable length.
> The longer the cable, the more capacitance that has to be driven within a specific time window.
> The second is how many instruments are turned on.
> Instruments that are off apply a loading to the bus that is more significant that active instruments (maybe?).
> I think the max allowable between any active instruments at any point in the bus is 4 meters (?).
> If there are inactive instruments, I think that maximum active device to device length shortens...
> Did I set off anyone's B.S. detector?
Nope, but here is the text from an Agilent 82350A manual:
** The recommended method for connecting a GPIB system is a linear arrangement
with the system controller (PC) at one end of the system. However, a GPIB
system can also be connected together in a star, linear and a combination
configuration as long as the total number of devices is <=15 and these
guidleines are followed:
* Minimize cable length as much as possible. All system devices must have
tri-state drivers and must be powered on. Systems with devices not using
tri-state drivers are limited to <250Kbytes/sec. Turning devices on or off
while a system is running may cause faulty operation.
* For operation with data transfer rates <500Kbytes/sec, the total length of all
GPB cables is <= 2 meters times the number of devices connected together, up to
a maximum of 20 meters.
* For operation with data transfer rates >500Kbytes/sec the total length of all
GPIB cables is <=1m times the number of devices connected together, up to a
maximum of 15 meters.
* The length between adjacent devices is not critical as long as the overall
restriction is met. GPIB bus extenders are available that allow operation over
much greater distances.
examples of how to do this using SocketWrench on this list, but they all
dealt with ASCII strings. I need to send data that is not ASCII strings. I
have tried SocketWrench using the ReadBytes method, but I can't seem to
figure out how to read back the data array. I initialize a unsigned integer
array and pass it to the method, but when I read it back after the method
completes, the buffer has not changed.
I have also tried using .Net to accomplish this task, but I run into the
same problem using the ReadFrom method.
Can anyone help me out? I am running Vee Pro 7.
Brad Avants
