Shawn,
Thanks for the explanation - it was good to have my suspicions
confirmed. From my experience, it seems that servicing events from
multiple sources using some fairly complex code can be done with little
problem provided the event code does not use common User Functions (in
fact, it shouldn't use User Functions also found in the application's
non-event code.
Barrie
non-event code.
Barrie
