Have a look at
www.my-vee.de under downloads for some windowstyle toolbars .
For vee-style otherwise have a look at the examples and libs folder ...
Depending on your vee version
Best regards,
detlef
Von: Carlos Jimnez [mailto:cjimenez@ivic.ve]
Gesendet: Mittwoch, 31. August 2005 14:37
An: VRF
Betreff: [vrf] Standard Toolbars Example
Wichtigkeit: Hoch
Instituto Venezolano de Investigaciones Cientificas - Venezuelan Institute
for Scientific Research -I.V.I.C.- Caracas, VENEZUELA.
Solo para uso institucional, de acuerdo con la ley - Only for institutional
use, according to the law.
Para informacion adicional - Additional information contact:
Best regards,
detlef
An: VRF
Wichtigkeit: Hoch
And your system is a perfect help!
Just show one other problem when we send examples - sometime same name for
different versions....
Maybe we have to send our samples with a short acronym and the used Vee
-version..
Like V75dB-Toolbar.vee
Best regards,
detlef
Von: Shawn Fessenden [mailto:shawn@testech-ltd.com]
Gesendet: Mittwoch, 31. August 2005 16:33
An: VRF
Betreff: RE: [vrf] Standard Toolbars Example
http://www.oswegosw.com/SearchVRF.php?an=toolbar
Sent: Wednesday, August 31, 2005 7:37 AM
To: VRF
Subject: [vrf] Standard Toolbars Example
Importance: High
Somebody could please give me some example of toolbars typical for common
applications, that is to say: row, column, or block of on screen buttons or
icons that, when clicked, activate certain functions of the program.
Thank You and Best Regard,
Carlos Jimenez
You are currently subscribed to vrf as: shawn@testech-ltd.com
You are currently subscribed to vrf as: Detlef.Baranski@pilkington.de
