Yes, i know - it is described in the manual, and it has been discussed in
the VRF, and of course - I did it with my elder computers - but now I did
not know why it does not work on a Japanese machine:
Problem : NI-GPIB Card for laptop
Questions: What is the best way to install IO-Lib 14, Vee7.5 and a NI - GPIB
card?
What I did:
I did install io-lib 14 as described as first,
Then I do install Vee 7.5,
Then I plugged in the PCMCIA -Card, then it was asking for drivers-
So driver was installed via CD-Rom which is 3 years old- Version 2.x
whatever.
The card is working in iolib14, but within Vee the instrument manager is
ghosted- no access to this card.
Do I really need to install the NI VISA lib 3.x or higher to run ?
I was thinking that this is not needed anymore with using iolib14....
Clarification needed! Thanks for your support,
detlef
This message and any attachments are confidential, for the exclusive use of
the addressee and may be legally privileged. Any other distribution, use or
reproduction is unauthorised and prohibited. If you have received this
message in error, please notify the sender immediately and delete the
message from your system.
Visit our internet site at http://www.pilkington.com
card?
What I did:
whatever.
detlef
