Or put asInt32("#B"+A) in the TO STRING object and use one VEE object
less...
--- Mike Groves <mike@grovesnet.org> wrote:
> Hi Ashley,
> In a formula box, use asInt32("#B"+A), where A = your binary string.
> Then if
> you need it converted to a HEX string, you can put it through a TO
> STRING
> box and select HEX.
> Cheers,
> Mike Groves
> -----Original Message-----
> From: Ashley Derrick [mailto:ashley@smartsolutions.karoo.co.uk]
> Sent: Thursday, June 30, 2005 1:36 PM
> To: VRF
> Subject: [vrf] BIN TO HEX CONVERSION
> HI,
> HOW DO I CONVERT A TEXT STRING WHICH IS A BINARY PATTERN
> REPRESENTATION TO
> HEX USING A FORMULA OBJECT?
> FOR EXAMPLE "111" WOULD GIVE HEXADECIMAL VALUE 7
> THANKS,
> ASHLEY
____________________________________________________
Yahoo! Sports
Rekindle the Rivalries. Sign up for Fantasy Football
http://football.fantasysports.yahoo.com
less...
> Hi Ashley,
> Then if
> STRING
> box and select HEX.
> Cheers,
> Mike Groves
> To: VRF
> HI,
> REPRESENTATION TO
> THANKS,
> ASHLEY
Yahoo! Sports
