<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML><HEAD><META http-equiv=Content-Type content="text/html; charset=us-ascii"><META content="MSHTML 6.00.2900.2523" name=GENERATOR></HEAD><BODY style="MARGIN: 4px 4px 1px; FONT: 10pt Tahoma; COLOR: #000000"><DIV dir=ltr align=left><SPAN class=578441214-04012005>Check your filename again. You have a UL were a DL should be or vice versa.</SPAN></DIV><DIV dir=ltr align=left><SPAN class=578441214-04012005></SPAN> </DIV><DIV dir=ltr align=left><SPAN class=578441214-04012005></SPAN> </DIV><DIV dir=ltr align=left><SPAN class=578441214-04012005>Rufus</SPAN></DIV><BR><DIV class=OutlookMessageHeader lang=en-us dir=ltr align=left><HR tabIndex=-1><B>From:</B> Ed Shaw [mailto:eshaw@comtechefdata.com] <BR><B>Sent:</B> Monday, January 03, 2005 2:28 PM<BR><B>To:</B> VRF<BR><B>Subject:</B> [vrf] File error 700<BR><BR></DIV><DIV></DIV><DIV>Hello All,</DIV><DIV> </DIV><DIV>I get a strange file error 700. I've attached a jpeg showing the error. I've highlighted the from file input pin which shows the correct valid filename. The error says it can't find a different filename. Any suggestions?</DIV><DIV> </DIV><DIV>Ed</DIV>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></HTML>
means that they do not control flow like solid lines... and that in turn
means that the from file filename is not being set before the object is
fired.
Now, from what I recall, UserFunctions _do_ set all of the control pins
first, but your 'Start' object ( which is not required for normal use -
personally I don't like them apart from testing ) is constraining the
program to start the flow before setting the control pins.
You can solve this by either:
removing the Start object
or:
ensure that the control pin is set before firing the object. I normally
do this by wiring the output of my 'setting' object ( e.g. a formula object
that creates a file name ) to both the control input pin and the sequence
input pin.
Message text written by "Ed Shaw"
>Hello All,
suggestions?
Ed<
Happy New Year ( to all )!
Mike Watts
_______________________________________________________________________
Michael Watts, Consultant PO Box 92
on the web: www.PreciselySo.Co.UK Exeter,Devon
e-mail: MJWC@PreciselySo.Co.UK England
tel: +44 7714 339 729 EX4 2YY
