Matt,
It wasn't my question, but "finding the zero crossing point is
relatively simple" is quite a bit confusing:( Care to post a VEE
example?
-Vinod
--- "BRADLEY,MATTHEW J (Non-A-Sonoma,ex1)"
<matthew_bradley@non.agilent.com> wrote:
> Daniel,
> For each period, use the maxIndex and minIndex functions.
> If you have to find the start and stop position of each period,
> finding the zero crossing point is relatively simple.
> From the original time signal, form two signals. For the first one,
> duplicate the last value and add it to the end.
> For the second one, duplicate the first value and add it to the
> beginning. Now, multiply the two signals. The crossing points are
> where the product is <= 0. To find those,
> make an array corresponding to the total time of your signal (+ 1
> sample). Use build coord to make a coord array of time (x) and
> product of the shifted signals (y). Sort based on y using
> the sort formula, and only use those with y <= 0. The corresponding
> x's are your zero crossing points.
> The result might have to be shifted by one sample. Not sure -- did
> this about four years ago. Let me know if it helps.
> -Matt Bradley
> -----Original Message-----
> From: Hynatec [mailto:oldenziel@hynatec.com]
> Sent: Thursday, August 11, 2005 11:34 AM
> To: VRF
> Subject: [vrf] detection of max and min in a signal
> Dear ladies and gentlemen.
> I would like to solve the following problem.
> I made a registration of a oscillating signal.
> Now I would like to detect the values of the maxima and minima for
> each oscillation (period)
> Additionally I would like to detect the positions of these values
> (time scale) for instance referred to the intersection point of the
> zero-value (signal can be set symmetrically around zero)
> Has somebody already realized such e threat.
> I realized already something that works, but very complicated.
> I thank you in advance for a response.
> Best regards,
> Daniel Oldenziel
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
example?
-Vinod
> Daniel,
> -Matt Bradley
> To: VRF
> Best regards,
> Daniel Oldenziel
Do You Yahoo!?
