<HEAD><TITLE>Serial problem</TITLE><META content="MSHTML 6.00.2800.1400" name=GENERATOR></HEAD><BODY><DIV>I have 4 WinNT 4.0 workstations with all the latest updates running VEE 5.01. All of the workstations are networked to common shared resources. I send data out of the serial port to a B&B RS-232 to CAN converter for DeviceNet support.</DIV><DIV> </DIV><DIV>Only one of these workstations displays this problem. Restarting VEE does not help. Rebooting does not help. Disconnecting the network does not help. Changing to another CAN converter does not help. Upgrading the IO libraries version does not help. Changing to the other internal COM port works briefly.</DIV><DIV> </DIV><DIV>What DOES work is to disconnect the RS-232 port from the B&B converter, then send out serial data and attempt to receive serial data from that open port. This deliberately generates another error. </DIV><DIV> </DIV><DIV>Following the deliberate error, communication through the serial port is restored until the same error occurs again, usually a week later. My technicians have instructions on how to reset using this technique.</DIV><DIV> </DIV><DIV>I don't understand why only one of my computers has this problem. They are all of the same manufacturer (HP), configured the same way. Apparently this problem is still lurking in the background, and is OS independent. But is it still in the later VEE revisions? I'm suspecting that it may be hardware timing dependent.</DIV><DIV> </DIV><DIV>George Tyrrell</DIV><DIV>TestDynamics LLC</DIV><DIV>Thornton, Colorado<BR><BR><BR>-----Original Message----- <BR>From: "Andersen, Dave-P26278" <DAVE.ANDERSEN@GDC4S.COM><BR>Sent: Sep 13, 2005 10:17 AM <BR>To: VRF <VRF@AGILENT.COM><BR>Subject: RE: [vrf] Serial problem <BR><BR></DIV><ZZZHTML><ZZZHEAD><ZZZMETA content="text/html; charset=us-ascii" http-equiv="Content-Type"><ZZZMETA name="GENERATOR" content="MSHTML 6.00.2800.1505"></ZZZHEAD><ZZZBODY><DIV dir=ltr align=left><FONT face=Arial color=#0000ff size=2><SPAN class=604280616-13092005>I have run into this problem also and I do not have any other program running and am using a real com port. In fact, I can run the program, stop it (with an execute close), and when I restart I get the message. Could this be an XP issue? I don't recall this problem before running XP.</SPAN></FONT></DIV><DIV dir=ltr align=left><FONT face=Arial color=#0000ff size=2><SPAN class=604280616-13092005></SPAN></FONT> </DIV><DIV dir=ltr align=left><FONT face=Arial color=#0000ff size=2><SPAN class=604280616-13092005>Dave</SPAN></FONT></DIV><DIV><BR></DIV><DIV class=OutlookMessageHeader lang=en-us dir=ltr align=left><HR tabIndex=-1><FONT face=Tahoma size=2><B>From:</B> g.nied@gn-software.de [mailto:g.nied@gn-software.de] <BR><B>Sent:</B> Monday, September 12, 2005 2:53 AM<BR><B>To:</B> VRF<BR><B>Subject:</B> Re: [vrf] Serial problem<BR></FONT><BR></DIV><DIV></DIV><DIV style="FONT: 10pt Courier New; COLOR: #000000">Tim,</DIV><DIV style="FONT: 10pt Courier New; COLOR: #000000"> </DIV><DIV style="FONT: 10pt Courier New; COLOR: #000000">the error message is leading you to the wrong direction. It only means that VEE cannot communicate with the port through the SICL library.</DIV><DIV style="FONT: 10pt Courier New; COLOR: #000000">So the problem might be:</DIV><DIV style="FONT: 10pt Courier New; COLOR: #000000">- another program took control over that specific serial port and did not close it</DIV><DIV style="FONT: 10pt Courier New; COLOR: #000000">- if the serial port is only a virtual one (USB) and the USB connection was disturbed</DIV><DIV style="FONT: 10pt Courier New; COLOR: #000000">In those cases a restart of VEE might be the solution, because SICl checks for the ports only once at VEE start.</DIV><DIV style="FONT: 10pt Courier New; COLOR: #000000"> </DIV><DIV style="FONT: 10pt Courier New; COLOR: #000000">I hope that helps a bit,</DIV><DIV style="FONT: 10pt Courier New; COLOR: #000000"> </DIV><DIV style="FONT: 10pt Courier New; COLOR: #000000"><DIV><DIV> </DIV><DIV>best regards,</DIV><DIV> </DIV><DIV>Georg</DIV><DIV> </DIV><DIV> </DIV><DIV><IMG src="cid:604280616@13092005-03BF"></DIV><DIV><FONT face="Century Gothic">Georg Nied Software-Development Hansestr. 7 51149 Cologne Germany</FONT></DIV><DIV><FONT face="Century Gothic">Tel: +49 (2203) 9770915 Fax: +49 (2203) 9770924 E-Mail: </FONT><A href="mailto:info@gn-software.de"><FONT face="Century Gothic">info@gn-software.de</FONT></A></DIV></DIV></DIV><DIV style="FONT: 10pt Courier New; COLOR: #000000"> </DIV><BLOCKQUOTE style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px"><TABLE id=tobit_repfor style="BORDER-RIGHT: #e0e0e0 1px solid; BORDER-TOP: #e0e0e0 1px solid; FONT: 10pt Arial; BORDER-LEFT: #e0e0e0 1px solid; COLOR: black; BORDER-BOTTOM: 0px" cellSpacing=0 cols=3 cellPadding=0 width="99%" border=0><TBODY><TR borderColor=#dfdfdf borderColorLight=#dfdfdf bgColor=#dfdfdf><TD style="PADDING-LEFT: 4px; PADDING-BOTTOM: 1px; PADDING-TOP: 1px; BORDER-BOTTOM: #ffffff 1px solid" width=140 colSpan=2 height=22><DIV style="FONT: bold 9pt Arial">Original Message </DIV></TD><TD style="BORDER-BOTTOM: #ffffff 1px solid" align=right><DIV style="FONT: 8pt Arial"><DIV style="FONT: 8pt Arial"><STRONG><FONT color=#808080> processed by David InfoCenter</FONT></STRONG> </DIV></DIV></TD></TR></TBODY></TABLE><TABLE id=tobit_repfor2 style="BORDER-RIGHT: #e0e0e0 1px solid; BORDER-TOP: 0px; FONT: 8pt Tahoma; BORDER-LEFT: #e0e0e0 1px solid; COLOR: black; BORDER-BOTTOM: #e0e0e0 1px solid" cellSpacing=0 cols=2 cellPadding=0 width="99%" border=0><TBODY><TR style="PADDING-BOTTOM: 2px"><TD style="PADDING-LEFT: 6px; BORDER-BOTTOM: #ffffff 1px solid" width=68 bgColor=#efefef height=18><DIV style="FONT: 8pt Tahoma">Subject: </DIV></TD><TD style="PADDING-LEFT: 4px; BORDER-BOTTOM: #efefef 1px solid" bgColor=#ffffff><DIV style="FONT: 8pt Tahoma">[vrf] Serial problem (09-Sep-2005 16:08)</DIV></TD></TR><TR style="PADDING-BOTTOM: 2px"><TD style="PADDING-LEFT: 6px; BORDER-BOTTOM: #ffffff 1px solid" width=68 bgColor=#efefef height=18><DIV style="FONT: 8pt Tahoma">From: </DIV></TD><TD style="PADDING-LEFT: 4px; BORDER-BOTTOM: #efefef 1px solid" bgColor=#ffffff><DIV style="FONT: 8pt Tahoma"><A href="mailto:Tim.Fisher@gdc4s.com">Tim.Fisher@gdc4s.com</A></DIV></TD></TR><TR style="PADDING-BOTTOM: 0px"><TD style="PADDING-LEFT: 6px" width=68 bgColor=#efefef height=17><DIV style="FONT: 8pt Tahoma">To: </DIV></TD><TD style="PADDING-LEFT: 4px" bgColor=#ffffff><DIV style="FONT: 8pt Tahoma"><A href="mailto:vrf@agilent.com">vrf@agilent.com</A></DIV></TD></TR></TBODY></TABLE><DIV> </DIV><ZZZ!-- -- format rtf text from Converted><P><FONT face=Arial size=2>Hello all,</FONT> </P><P><FONT face=Arial size=2>I am receiving a serial error which I'm sure has come up before for others, so maybe I can get some advice. I am receiving a VEE Run Time Error</FONT></P><P><FONT face=Arial color=#ff0000 size=2>I/O error or timeout occurred SICL call made with bad parameter</FONT> </P><P><FONT face=Arial color=#ff0000 size=2>Unable to set receive buffer size of X bytes</FONT> <BR><FONT face=Arial color=#ff0000 size=2>In transaction number 1</FONT> </P><P><FONT face=Arial size=2>I have tried a wide range of values for the receive buffer (X = 32 to 8192)</FONT> <BR><FONT face=Arial size=2>But none of the values have worked. Also the problem only seems to occur when the remote host is connected to a shared network.</FONT></P><P><FONT face=Arial size=2>Any help would be appreciated.</FONT> </P><P><FONT face=Arial size=2>Thanks,</FONT> <BR><FONT face=Arial size=2>Tim Fisher</FONT> </P></BLOCKQUOTE></ZZZBODY></ZZZHTML></BODY>---You are currently subscribed to vrf as: rsb@soco.agilent.comTo subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
> an option to build a tool bar in
> vee, like File, Edit ect
Well I think that's a menu bar - but no, not as such. Not directly anyway.
However, you can use a MenuBar control. There's also a ToolBar control if
that's more suited to your purpose (both are part of several different
development environments. There are also several independent versions of
each control).
Several examples can be found for each (using MS versions):
http://www.oswegosw.com/SearchVRF.php?an=menu
http://www.oswegosw.com/SearchVRF.php?an=tool
-SHAWN-
each control).
-SHAWN-
each control).
-SHAWN-
