Yes.
An airborn spy system had a tuner programmed with a serial port (actually an
RS-485). The test procedure said to enter the commands using a VT-100
terminal. When automating the test, VEE was used to send the commands as
part of the testing process. What the book said about the tuner and how the
tuner actally performed were different. I discovered that a VT-100 is a lot
more forgiving than VEE about framing, baud rate, and parity. When that was
discovered, there were no problems. The book was wrong.
RS-232, RS-422, and RS-485 are hardware and electrical differences easily
taken care of with converters. The essential part was the serial port
behavior as far as framing.
Robert Reavis
Warm Springs Computer Works
Fremont, California
----- Original Message -----
To: "VRF" <vrf@agilent.com>
Sent: Wednesday, January 12, 2005 7:13 AM
Subject: [vrf] Serial Terminal emulation...
> Hi vrf,
> Has anyone had to emulate a VT100 through the RS232, using direct I/O's?
> Just no reponse from the piece of kit I'm trying to contact, but works
> fine
> in Hyperterminal.
> All the stop bits, parity baud rate etc etc are correct - just appears to
> be this lack of VT-100 emulation causing the trouble.
> If anyone has ever had to do this slightly strange requirement, it would
> be
> great to hear from you...
> Many thanks,
> Al.
> (VEE 7, I/O libraries M, Win2000)
> You are currently subscribed to vrf as: robert@wscw.com
Robert Reavis
Fremont, California
> Hi vrf,
> fine
> in Hyperterminal.
> be
> Many thanks,
> Al.
Just no reponse from the piece of kit I'm trying to contact, but works fine
in Hyperterminal.
If anyone has ever had to do this slightly strange requirement, it would be
Many thanks,
Al.
