Thomas,
I have seen this before with the "From String" objects; often it is due
to the particular transaction requiring some input which is not
satisfied by the input string. You may want to post your sample code
for someone to have a look.
Shawn,
Thomas may not be referring to any File I/O, the error is common to the
String objects as well.
-Vinod
--- tw@huber-online.com wrote:
> Hello everybody,
> I get a message " end of file or no data found" object title: from
> string, object type: from string , Error Nr. 701 , in transaction Nr.
> 1.
> but not in development surrounding !?
> Is that a problem with a error output?
> regards Thomas
____________________________________________________
Start your day with Yahoo! - make it your home page
http://www.yahoo.com/r/hs
Shawn,
-Vinod
> Hello everybody,
> 1.
> regards Thomas
