vrf USB devices that work as serial ports
Question asked by VRFuser on Apr 11, 2005
<font size=2 face="sans-serif">I've had very good luck using Edgeportdevices from ionetworks</font>
<font size=2 face="sans-serif">Edgeport/8 USB to 8 port RS-232 DB-9Serial Converter 301-1002-08</font>
<font size=2 face="sans-serif">http://www.ionetworks.com/products/usbtoserialconverters/</font>
<table width=100%><tr valign=top><td width=40%><font size=1 face="sans-serif"><b>"Gregg C Levine"|landocalrissian@att.net></b> </font><p><font size=1 face="sans-serif">04/08/2005 09:38 AM</font><table border><tr valign=top><td bgcolor=white><div align=center><font size=1 face="sans-serif">Please respond to
"Gregg C Levine" |landocalrissian@att.net></font></div></table>
<td width=59%><table width=100%><tr valign=top><td><div align=right><font size=1 face="sans-serif">To</font></div><td><font size=1 face="sans-serif">VRF |vrf@agilent.com></font><tr valign=top><td><div align=right><font size=1 face="sans-serif">cc</font></div><td><tr valign=top><td><div align=right><font size=1 face="sans-serif">Subject</font></div><td><font size=1 face="sans-serif">RE: [vrf] USB devices that work as serialports</font></table>
<table><tr valign=top><td><td></table>
</table>
<font size=2><tt>Hello from Gregg C Levine
Basically in general. I'm using the Belkin gizmo, because that's what Ihave
in inventory. I was curious who else was using these devices. But alsothe
FTDI based devices.
Gregg C Levine landocalrissian atsign att dot net
"They were in the wrong place at the wrong time. Naturally they became
heroes." Leia Organa of Alderaan, Senator
> -----Original Message-----
> From: Antti.Suhonen@elektrobit.com [mailto:Antti.Suhonen@elektrobit.com]
> Sent: Friday, April 08, 2005 1:52 AM
> To: VRF
> Subject: RE: [vrf] USB devices that work as serial ports
> Hi all,
> I'm using FTDI's usb to 232 gear in several stations. With it, prosare
> you're able to set clock divisor and sub-integer divisor by editing
> driver ini; this allows 'aliasing' non-standard bitrates up to
> 921.6kbps; I had an application where I needed to reproduce 250000bpsFD
> RS485. As VEE has this validBaudRates constraint and maximum rateis
> 230.4kbps, I had a problem: 230.4k was not even close to 'magical'3%
> range. This device though solved it, just mangled the ini to alias
> 2400bps as 250k, set VEE device to 2k4 and off I went...
> Did you mean who's using Belkin-branded or just generally? ;D
> -Antti
> From: Gregg C Levine [mailto:landocalrissian@att.net]
> Sent: 7. huhtikuuta 2005 22:24
> To: VRF
> Subject: [vrf] USB devices that work as serial ports
> For reasons that most people would not be interested in, I boughta
> Belkin USB to serial adapter, it's their model for talking to PDAs.It
> works well enough here, to add a third serial port to the system.
> However, how many people, other then me are using a similar adapterto
> communicate with their applications via the serial interface?
> "They were in the wrong place at the wrong time. Naturally theybecame
> You are currently subscribed to vrf as: Antti.Suhonen@elektrobit.comTo
> subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".
> To send messages to this mailing list,  email "vrf@agilent.com".
> Please note: This e-mail may contain privileged and confidential
> information and is intended solely for the addressee. If you are
> not the intended recipient or an employee responsible for
> delivering this message to the intended recipient, you are
> hereby notified that any review, publication, dissemination,
> distribution, copying or use of the information in this message
> is strictly prohibited. If you have received this e-mail by
> error, please notify the sender immediately by replying to the
> message and subsequently delete it from your system.
> E-mail is susceptible to data corruption, interception,
> unauthorized amendment, tampering and viruses. We only send and
> receive e-mail messages on the basis that we are not liable for
> any such corruption, interception, amendment, tampering,
> viruses, any other reprehensible acts or any consequences of
> the aforementioned.
> You are currently subscribed to vrf as: landocalrissian@att.net
You are currently subscribed to vrf as: mnalepinski@baneng.com
</tt></font>
---You are currently subscribed to vrf as: rsb@soco.agilent.comTo subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list,  email "vrf@agilent.com".  If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
