vrf Looking for a temperature monitor with USB interface, w ill need to communicate to it from ATE app.
Question asked by VRFuser on Aug 14, 2005
David,
I just received the measurement computing USB unit for temperature reading
USB-TC. I also bought the Universal library for VEE from them so I can use
it directly from my VEE app. It also comes with drivers for other software.
I use it with K wire for reading part temperatures. Check
www.measurementcomputing.com and USB DAQ selection.
Stan
From: Belliveau, David A (US SSA) [mailto:david.belliveau@baesystems.com]
Sent: Monday, August 15, 2005 2:06 PM
To: VRF
Subject: [vrf] Looking for a temperature monitor with USB interface, will
Hello all,
I am looking for a USB-based temperature monitor, exclusively for tracking
the temperature drift inside of a test rack system.
I would like something that I can communicate with via my ATE application.
Most of the ones I found so far have their own dedicated software
application, but I want to talk to it from my ATE application.
I can handle any driver style (DLL, etc.) assuming the documentation is OK.
If it does more than just temperature, that's OK, too (e.g. - humidity)...
Does anyone have a recommendation?
Thanks for helping out...
DAB
You are currently subscribed to vrf as: StanGunsolus@motorola.com To
subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".
