Sacha,
It looks like the 3rd box did not have an equal for A. When you add-in
A=123, then it running fine.
Han
[mailto:sspangenberg@agilent.com]
Sent: Friday, June 03, 2005 7:36 AM
To: VRF
Subject: [vrf] Matlab: Adding Ouput causes Error 405
Any idea why the 3rd matlab call in the attached file does not work?
I picked some matlab function from the fnuction browser and changed the
formula to do something trivial such as Y=123;
I then added another formular A=123; in the matlab script box,
added an A output pin and now get error 405...
See the example.
Also interestingly when I copy the matlab script object which
contains the Y= and A= lines and paste it back then only Y= appears
in the copied box.
Seems a bit strange to me..
Sascha
You are currently subscribed to vrf as: tranh@tycoelectronics.com
Han
To: VRF
See the example.
in the copied box.
Sascha
It seems that things never stay the same for very long.
After almost 4 years of supporting VEE I'll be leaving Support to do
other things; today is my last day doing VEE Support. While I'll still
be a member of the vrf, my new job responsibilities will not allow me to
be as active as I have been in past.
The vrf has truly been one of the highlights of my workday for the past
few years.
I wish you all health and happiness and continued pleasure in VEE and
the vrf.
Best Regards to All,
Scott Bayes
Agilent Technologies, Inc.
815 14th Street S.W.
Loveland, CO, U.S.A. 80537
970 679 3799 Tel
970 635 6867 Fax
