I just got this information when asking support about this.
"It seems that VEE 7.51 supports only the traditional NI-DAQ 7.4 drivers, not the new NI-DAQmx drivers."
I was planing of using one of the low cost USB DAQ the have, since the support wasn't there I've stick to a spare solution.
Hlsningar/Regards
Ulf Jakobsson
Production Quality
AMC Centurion AB
P.O.Box 500, S-184 24 kersberga, Sweden
Tel direct +46 8 555 724 25
e-mail:ulf.jakobsson@centurion.se
www.centurion.com
Sent: den 28 juni 2005 15:59
To: VRF
Subject: Re: [vrf] Help with VEE 7.5 and NI-DAQ
Thanks to a clue from Willie Kiely <Willie.Kiely@bourns.com>, I
figured out that VEE 7.5 currently only supports older National Instruments
hardware. Specifically, it only supports hardware that can be programmed
with the "Traditional NI-DAQ (Legacy)" driver.
So, I added an older NI PCI-MIO-16E-1 to my system, VEE found it, and
I was able to acquire data.
I also added a National Instruments PCI-5431 video signal generator
to my system. That worked pretty much "out of the box".
I haven't used VEE 7.5 much, but my impression is that Agilent's done
a better job integrating NI's instruments (scopes, DMMs, arbs, etc.) than
they've done integrating NI's general purpose DAQ boards. I suspect the
VEE team is working on support for NI-DAQmx, which should improve usability.
Brian
"Brian H. Powell" wrote...
> I've got VEE 7.51 and a National Instruments PCI-6251 Data
> Acquisition card. I'm getting an error trying to do a simple read. I
> think I'm just confused about what to do. Anybody have any advice or
> experience?
> I'm using I/O -> Instrument Manager. "Find Instruments" doesn't see
> this device, but it does find a couple of other devices (a 34401A and a
> National Instruments PCI-5431 arb). I've tried setting up the NI-DAQ
> device manually in the Instrument Manager, and I think I'm just not doing
> that correctly.
> The error I'm getting says...
> Error returned from NIDAQ NIxxxx_init() function call, error value
0xbfff0012
> Error number: 818
> NI-DAQ Error 18: Unknown NI-DAQ error code.
> Error returned from calling init function:
> AGniDaq_init("Dev1", FALSE, TRUE, &handle);
> Possibly, the configured address string is incorrect. The address
> should be in the form 'DAQ::<deviceNumber>' or 'PXIn::<deviceNumber>'
> or 'SCXIn::<deviceNumber>'. Check the deviceNumber in NI MAX.
> Also, check the instrument connections and power.
> In MAX, the device is called "Dev1". I also tried changing the value
> in VEE to "DAQ::0" with the same error. ("DAQ::1" refers to the
> PCI-5431.) I also tried renaming my device in MAX from "Dev1" to "DAQ::0",
> but that's not a legal name.
> By the way, I'm running NI-DAQ 7.3.
> Also, is there an official list of National Instruments devices that
> are supported in VEE? My 6251 is a pretty new device; maybe VEE just
> doesn't support it yet.
> Thanks for any help or advice.
> Brian
You are currently subscribed to vrf as: Ulf.Jakobsson@centurion.se
Hlsningar/Regards
Ulf Jakobsson
Production Quality
AMC Centurion AB
www.centurion.com
To: VRF
Brian
> experience?
> that correctly.
0xbfff0012
> Error number: 818
> Brian
experience?
that correctly.
Error returned from NIDAQ NIxxxx_init() function call, error value 0xbfff0012
Error number: 818
Brian
