"Coombs, Dean (N-Outsource Consulting) <dean.coombs@lmco.com> wrote:
> Any VI's out there in VEE-land that can read in TELEMETRY type (TLM)
> data streams?? To wit: At the SENDING end, we need to 1) Read in the TLM
> stream, 2) Convert it to a standard RS-232/422 type serial stream for 3)
> Application to a unit that goes from the RS serial to LAN/Ethernet. At
> the other (Receiving) end, we need to do the reverse, in order to
> recover the original TLM data stream.
I'd expect using a DLL would make a lot more sense than a native VEE routine.
That or an external routine called via "execute program".
Quick web search shows some possibilities at
http://www.amsat.org/amsat/ftpsoft.html#win-tlm
Stan
Stan
I think I have no problem with USB and Agilent 34980A.
My system is:
Windows XP Home Edition,
VEE Pro 7.03 and VEE Pro 7.03,
Agilent IO Library Suite 14.1,
I install NI-VISA as primary VISA and Agilent-VISA as secondary.
I recommend installing Agilent IO Library Suite 14.1 or 14.0
depending your OS.
(For fear that your VEE is broken.)
Re-install VEE. Or install evaluation version of the VEE 7.5
and chek with it.
FUKUI Yutaka
> "Drago, William @NARDAEAST" wrote:
> Hi Susan,
> Thanks for the reply. Does this look ok?
> Bill
> -----Original Message-----
> From: WOLBER,SUSAN (A-Loveland,ex1)
> [mailto:susan_wolber@agilent.com]
> Sent: Tuesday, December 06, 2005 1:58 PM
> To: VRF
> Subject: RE: [vrf] VEE vs LabView (formerly USB Headaches)
> Hello William,
> The behavior sounds like maybe you have multiple VISA's
> installed.
> Agilent VISA's VisaAssistant will use Agilent VISA. VEE's
> "Find" will use Agilent VISA.
> VEE's DirectIO will use whatever VISA is installed as
> Primary.
> In the IO Control, "About" will tell you if Agilent VISA
> thinks it is installed as Primary or Secondary.
> Hope that helps
> Sue
> VEE R&D
> From: Drago, William @NARDAEAST
> [mailto:William.Drago@L-3com.com]
> Sent: Tuesday, December 06, 2005 5:45 AM
> To: VRF
> Subject: [vrf] VEE vs LabView (formerly USB Headaches)
> All,
> I am using VEE to build an ATE system for a customer that
> swears by LabView.
> They have provided me with a specialized piece of test
> equipment and recommended I talk to it via USB rather than
> GPIB. But, as I said in my previous posts, VISA can *IDN?
> the instrument, but VEE can't.
> I just CAN'T call them up and tell them VEE doesn't work
> with their instrument when they're using LabView quite
> successfully. How humiliating is that?!
> So, one more time...
> I can successfully *IDN? using VISA Assistant.
> Find Instruments in Instrument Manager finds the device but
> says it fails to respond to *IDN?.
> *IDN? using Direct I/O in VEE times out. (I have double
> checked that my Read Terminator and EOL Sequence are
> correct.)
> Any and all ideas and suggestions are welcome including
> ideas for witty replies to my customer's emails belittling
> me for using VEE.
> Thanks,
> Bill
> Susan_Wolber@agilent.com
> "vrf@agilent.com".
> This e-mail and subsequent attachments may contain
> information which is proprietary to L-3 Communications
> Corporation. The contents shall not be disclosed, copied,
> distributed or used unless authorized by L-3 Communications
> Narda - East.
> William.Drago@l-3com.com
> "vrf@agilent.com".
> You are currently subscribed to vrf as: fukui.yutaka@jp.fujitsu.com
> This e-mail and subsequent attachments may contain information which
> is proprietary to L-3 Communications Corporation. The contents shall
> not be disclosed, copied, distributed or used unless authorized by L-3
> Communications Narda - East.
> IOLibs.jpg Type: JPEG Image (image/jpeg)
> Encoding: base64
* $BJ!0f!!K-!J (BFUKUI Yutaka)
* E-Mail: fukui.yutaka@jp.fujitsu.com
* $BIY;NDL3t<02q<R!!@n:j9)>l (B
* $B$b$N$E$/$j?d?JKIt!&@8;:5;=Q3+H/E}3gIt!!;n835;=Q (BPj <-- 2004/10/01 $B$h$j (B
$B?&@)$,JQ$j$^$7$? (B
* $B7WB,@_Hw3+H/It (BHomePage http://www.psl.fujitsu.co.jp/htd2/ksk/
* $B@n:j;TCf866h>e>.EDCf#4 (B- $B#1 (B- $B#1!!M9JXHV9f!' (B211-8588
* TEL $B!!30@~ (B 044-754-2238, $B!!Fb@~ (B 711-5-3153 <-- 2005/05/23 $B$h$jEEOCHV9f$, (B
$BJQ$j$^$7$? (B
* FAX $B!!30@~ (B 044-754-2434, $B!!Fb@~ (B 711-5-3178
