I'm sure that the variable is of the right type. I've done the same
program with VB .NET and it works perfectly.
The variable is a WinEASY_RemoteCtrl.Application object and OpenWsp is
a member of this class.
When I create the application object with VB .NET I've to write this code
on error resume next
set WEapp = CreatoObject("WinEASY_RemoteCtrl.Application")
on error goto 0
Do you think that I've to change the error processing in VEE as well
(if there is a way)?
Thanks.
Michele.
on error goto 0
Thanks.
Michele.
Or maybe it gets initialized to the wrong thing? Double click a line
carrying WEapp or get var info when the program dies (since it's declared)
and make sure it's the correct object.
-SHAWN-
