I've successfully used a E8491B IEEE-1394 PC Link to VXI, C-Size (FireWire) card to control a vxi chassis from VEE. It's a slot0
firewire controller. Much faster than gpib and it gets you away from an expensive, obsolete embedded controller in the VXI Chassis.
Mike
Michael N. Asbery (202)404-3014, DSN 754
US Naval Research Laboratory fax (202)404-7661
Code 5733.20 michael.asbery@nrl.navy.mil
4555 Overlook Ave SW
Washington DC 20375
From: Muckerheide, Paul [mailto:PMuckerh@SYSTEMS.TEXTRON.com]
Sent: Thursday, November 17, 2005 4:05 PM
To: VRF
Cc: "'Vera Fernndez, Juan'"
Subject: RE: [vrf] vrf: VEE & VME
I am not sure what you mean by VEE on a VME platform. I have put a VME card
in a VXI C-Size Chassis and talked to it through the Slot 0 Controller at
the register level using NI LabWindows/CVI. The VME Card was put on an
Agilent E1403C B size to C Size Adapter. I do not see why you could not use
VEE for this type of application. You would have to use the low level
commands in VISA to do peeks and pokes to the correct memory locations. The
VME card I used had a C API. You could call dlls from VEE.
If you are talking about a VME single board computer than I don't know. I
no longer have access to the set-up it is at my last job or I would try VEE.
Good Luck,
Paul
Sent: Thursday, November 17, 2005 10:00 AM
To: VRF
Cc: vrf@agilent.com
VME doesn't necessary mean UNIX. There some VME embedded processors (e.g.
Thales) supporting WIN2K and XP. My concern is certainly IO, i.e. will VEE
able to talk to a VME device? Actually SCIL/VISA does support GPIB, USB,
TCP/IP, VXI, COM ports, ... but how about VME?
I know VXI is really a VME extension for instrumentation so I thought some
kind of solution might exist out there.
Juan
-----Mensaje original-----
De: Shawn Fessenden [mailto:shawn@testech-ltd.com] Enviado el: jueves, 17 de
noviembre de 2005 15:21
Para: VRF
Asunto: RE: [vrf] vrf: VEE & VME
> Is VEE able to run on a VME platform?
It might run under WINE. IO would probably be a challenge, but it shouldn't
be too difficult to get around that.
-SHAWN-
Este correo electrnico y, en su caso, cualquier fichero anexo al mismo,
contiene informacin de carcter confidencial exclusivamente dirigida a su
destinatario o destinatarios. Queda prohibida su divulgacin, copia o
distribucin a terceros sin la previa autorizacin escrita de Indra. En el
caso de haber recibido este correo electrnico por error, se ruega notificar
inmediatamente esta circunstancia mediante reenvo a la direccin
electrnica del remitente. POR FAVOR, ANTES DE IMPRIMIR ESTE CORREO
ELECTRNICO CONSIDERE SU APORTACIN A LA CONSERVACIN DEL MEDIO AMBIENTE POR
LA REDUCCIN DE CONSUMO DE PAPEL.
The information in this e-mail and in any attachments is confidential and
solely for the attention and use of the named addressee(s). You are hereby
notified that any dissemination, distribution or copy of this communication
is prohibited without the prior written consent of Indra. If you have
received this communication in error, please, notify the sender by reply
e-mail. PLEASE CONSIDER YOUR ENVIRONMENTAL RESPONSIBILITY BEFORE PRINTING
THIS E-MAIL.
You are currently subscribed to vrf as: PMuckerh@systems.textron.com To
subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".
You are currently subscribed to vrf as: michael.asbery@nrl.navy.mil
Mike
Washington DC 20375
To: VRF
Good Luck,
Paul
To: VRF
Cc: vrf@agilent.com
Juan
Para: VRF
-SHAWN-
THIS E-MAIL.
