Hi Qi,
Yes, but no...
I want to do it in the program, I have a userfunction where I want the
caption of the textbox to change, depending on the parameters I call the
UF with. So I thought that one of the properties of the control could
allow me to change the title. I guess Ill have to use a textbox and a
lable as the title.
Nelson
qi_gao@agilent.com wrote:
> When you select Device->Windows Forms Control->TextBox, and place the TextBox on your workspace, the title you see ("TextBox") is the title of the .NET Control Host. A .NET Control Host is the VEE object that hosts/contains a .NET control. To change its title, you would change it like you change any other VEE objects - use the Properties grid.
> Is this what you're thinking about?
> Qi
> -----Original Message-----
> From: Nelson Mambre [mailto:nmambre@seebeck.com.ve]
> Sent: Tuesday, December 13, 2005 3:20 AM
> To: VRF
> Subject: [vrf] Change title of .NET Textbox
> Hi all,
> Is it possible to change the title of a textbox in .NET. I tried with
> TextBox.Name but it dont seem to work and TextBox.Text is just the
> content of the textbox.
> Any ideas?
> Thankz in advance,
> Nelson
Yes, but no...
lable as the title.
Nelson
> Qi
> To: VRF
> Hi all,
> Any ideas?
> Thankz in advance,
> Nelson
Any ideas?
Thankz in advance,
Nelson
