Hello from Gregg C Levine
Here's something for the bright people behind our list to ponder. I am
subscribed to this list using three e-mail addresses. One is this one,
the second one is also assigned to the same ISP, and the third is
assigned to GMail for obvious reasons.
Starting around the time I joined the list, but did not subscribe the
others, GMail had not been created then, and the other address wasn't
being used, I started seeing a lot of messages without the
characteristic signature of the list. Surprisingly enough a lot of
them came from our own Shawn Fesenden.
Gregg C Levine hansolofalcon@worldnet.att.net
"Remember the Force will be with you. Always." Obi-Wan Kenobi
http://www.lyris.com
-SHAWN-
