Bravo! it's doable!
I found a little error.
Field "b" of the declared variable "Outputs" should be type "TEXT".
Correct "Declare Outputs" and the second "Record" objects.
FUKUI Yutaka
"GAO,QI (A-Sonoma,ex1)" wrote:
> Hi Alex,
> It's not "easy", but it's doable. What you need to do is to declare couple Record variables, initialize them, and then pass them around to your callable VEE server. Please see attached program.
> Qi
> -----Original Message-----
> From: Alexander Poulikakos (KI/EAB) [mailto:alexander.poulikakos@ericsson.com]
> Sent: Monday, December 12, 2005 7:37 PM
> To: VRF
> Subject: [vrf] Callable VEE, how does it work?
> Hi VRF
> I'm trying to make a VEE application call another VEE application, via ActiveX.
> How can I do this? I have checked the examples and there is no example
> of VEE calling VEE. It's only various other applications calling VEE.
> I have attched a VEE example, but I just can't get it to work?!?!?
> What should the variable "Outputs" be initiated as?
> I get an error message telling me:
> "Value must be a 1 dimensional VARIANT array "Inputs" parameter of function "TwoInTwoOut"
> Any help is appreciated.
> Regards,
> Alex
> You are currently subscribed to vrf as: qi_gao@agilent.com
> If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
> Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
> You are currently subscribed to vrf as: fukui.yutaka@jp.fujitsu.com
> CalableVee_Example.vee Type: VEE Program (application/x-unknown-content-type-VEE.Program)
> Encoding: base64
> Description: CalableVee_Example.vee
* $BJ!0f!!K-!J (BFUKUI Yutaka)
* E-Mail: fukui.yutaka@jp.fujitsu.com
* $BIY;NDL3t<02q<R!!@n:j9)>l (B
* $B$b$N$E$/$j?d?JKIt!&@8;:5;=Q3+H/E}3gIt!!;n835;=Q (BPj <-- 2004/10/01 $B$h$j (B
$B?&@)$,JQ$j$^$7$? (B
* $B7WB,@_Hw3+H/It (BHomePage http://www.psl.fujitsu.co.jp/htd2/ksk/
* $B@n:j;TCf866h>e>.EDCf#4 (B- $B#1 (B- $B#1!!M9JXHV9f!' (B211-8588
* TEL $B!!30@~ (B 044-754-2238, $B!!Fb@~ (B 711-5-3153 <-- 2005/05/23 $B$h$jEEOCHV9f$, (B
$BJQ$j$^$7$? (B
* FAX $B!!30@~ (B 044-754-2434, $B!!Fb@~ (B 711-5-3178
Bravo! it's doable!
FUKUI Yutaka
> Hi Alex,
> Qi
> To: VRF
> Hi VRF
> Regards,
> Alex
> Encoding: base64
$BJQ$j$^$7$? (B
little curious... I want to see a picture of "the Queen"....
Nelson
