vrf vrf- ActiveX newbie question...
Question asked by VRFuser on Oct 27, 2005
Hi all,
I currently have a vee program controlling a radio
over a network.  The program is used for spectral
scanning (using the mag spectrum as the main
interface) and works pretty decent but I need some
help in a few areas.
Can someone point me in the right direction for
implementing click tune? I would like to click on the
spectrum and tune the radio to the current mouse
position.  I noticed that I can use the marker
feature, but I only want this to happen when the
cursor is moved.  The basic interface uses drop boxes
and text input to select receiver mod/bw/frequency/and
sweep size so the goal is to click on an active signal
and then capture the IF and audio.
Jeff
