vrf Time comparison
Question asked by rsb on Feb 26, 2001
"Lockwood, Mel" <Mel_Lockwood@adc.com> wrote:
> Hello all
> I want to compare a time cal against a now() and if the time cal is past due
> then I want it to change the record color to indicate that it is past due.
> The problem is the time cal that is inputted is not a time stamp format it
> may be 2/15/02 (Feb 15th 2002) or 12/2/02 (Dec 2nd 2002). I do not know how
> to convert these over to time stamp and then compare them.
> Any help in this would be appreciated.
> Thanks in advanced.
> Mel Lockwood
Use a From String with 3 outputs and three transactions, each reading
a single real value. Outputs are Month, Day, Year
Add 2000 to Year
Then use dmyToDate(Day,Month,Year)
to convert to time format. At this point you can directly compare with now()
regards
Stan
Stan Bischof  Agilent Technologies  707-577-3994  stan_bischof@agilent.com
