vrf dual processing?
Question asked by jay.johannes on Nov 7, 2005
Hi Dean,
HP never created drivers for these instruments (I was the manager of the
group that wrote them).  However, many people had success using the 8653B
driver with the A instrument.  It was simply a matter of not hitting a
couple of buttons for functions that didn't exist in the a model (or was it
that the freq and power ranges were different?  Been too long).
The 436 was a little trickier.  However there is an unsupported panel driver
(who cares, all panel drivers are unsupported these days) down in section 5
of the panel driver link page.  This driver was written by a very
knowledgeable field engineer and worked well.  The unsupported tag was more
a matter of politics at the time than a reflection on the quality of the
driver.
The following page lists the panel drivers for VEE:
http://adn.tm.agilent.com/index.cgi?CONTENT_ID=1879
The following are direct links to the files you need:
http://adn.tm.agilent.com/adn/veedrivers/unsupported/hp436a.id
http://adn.tm.agilent.com/adn/veedrivers/unsupported/hp436a.ih
http://adn.tm.agilent.com/adn/veedrivers/supported/hp8673b.id
http://adn.tm.agilent.com/adn/veedrivers/supported/hp8673b.ih
Jay Nemeth-Johannes
Smart Sensor Systems
720 SW 14th Street
Loveland, Colorado 80537
(970) 663-0006
www.SmartSensorSystems.com
> -----Original Message-----
> From: Coombs, Dean (N-Outsource Consulting)
> [mailto:dean.coombs@lmco.com]
> Sent: Monday, November 07, 2005 5:47 PM
> To: VRF
> Subject: RE: [vrf] dual processing?
> Can anyone out in VRF-land help me find drivers and/or VEE
> programs for a couple of OLDER H-P instruments?? I have not
> had any success finding usable drivers for them from either
> Agilent's or National's web sites.
> Maybe, there is, out there somewhere, a VEE program or
> panel-driver for these two pieces. The instruments are 1) H-P
> 436A power meter  and 2) H-P 8673A signal generator. Any
> input will be very much appreciated!
> Thanks!
> DPC
> Lockheed Martin
> Sunnyvale, CA
> From: Stan Bischof [mailto:rsb@soco.agilent.com]
> Sent: Thursday, November 03, 2005 7:10 AM
> To: VRF
> Cc: vrf@agilent.com
> Subject: Re: [vrf] dual processing?
> "Ivan Edwards" <ivan.edwards@irisys.co.uk> wrote:
> > I have an application requiring a lot of number crunching.  My IT
> > experts have suggested buying a whizzy PC with dual processors.
> Good advice. Anyone doing lots of simulations ( or "number
> crunching" )
> should have a dual ( or better) CPU machine. This allows full
> usage for
> number crunching without impacting other ongoing use of the machine.
> >   What will Vee do with them?
> Nothing directly since VEE is a single thread.
> >  They have asked is Vee SMP ready?
> No
> >  Can Vee run separate threads on each processor?
> No. But you certainly can run multiple VEE processes and the OS will
> assign those to processors as needed.
> >  Can anyone give me advice?
> Sure. If you really need to do serious number crunching write
> yourself an SMP routine in C or whatever. Then call that from VEE as
> needed. That gives you the best of both worlds.
> Stan
> Stan Bischof  Agilent Technologies  707-577-3994
> stan_bischof@agilent.com
> You are currently subscribed to vrf as: dean.coombs@lmco.com
> To send messages to this mailing list,  email "vrf@agilent.com".
> Search the "unofficial vrf archive" at
> "www.oswegosw.com/vrf_archive/".
> You are currently subscribed to vrf as: jay.johannes@completetest.com
Date: Mon, 07 Nov 2005 16:46:30 -0800
From: "Coombs, Dean (N-Outsource Consulting)" <dean.coombs@lmco.com>
To: Stan Bischof <rsb@soco.agilent.com>, VRF <vrf@agilent.com>
Can anyone out in VRF-land help me find drivers and/or VEE programs for
a couple of OLDER H-P instruments?? I have not had any success finding
usable drivers for them from either Agilent's or National's web sites.
Maybe, there is, out there somewhere, a VEE program or panel-driver for
these two pieces. The instruments are 1) H-P 436A power meter  and 2)
H-P 8673A signal generator. Any input will be very much appreciated!
Thanks!
DPC
Lockheed Martin
Sunnyvale, CA
To: VRF
Cc: vrf@agilent.com
Good advice. Anyone doing lots of simulations ( or "number crunching" )
should have a dual ( or better) CPU machine. This allows full usage for
No
Stan
